Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2005 big bear 400 front bearing replacement issue
Old 07-30-2018, 05:17 PM
Bbear400's Avatar
Default 2005 big bear 400 front bearing replacement issue
This is the side I'm having trouble with
This is the right side, 1/8" more gap.
Hi all having an issue with the new wheel bearings. I removed old ones from the front left , pressed the new ones in. My problem is when I tighten the axle nut the hub pulls in too far and runs on caliper. Can tell why it's happening almost like a spacer is missing. I don't want to take apart the right side just to see how it's setup on that side.
Old 07-31-2018, 06:23 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Haven't worked on one of these before, but here's a parts diagram that may help you see if you're missing any pieces.
Tla316
10-02-2023 02:57 AM
Dave1
07-16-2011 01:45 AM
bacchus
08-04-2009 10:54 AM
Quick Reply: 2005 big bear 400 front bearing replacement issue
