1/2 ton small block- can it tow one?
Old Mar 22, 2004 | 01:07 AM
MrZeeedler's Avatar
Default 1/2 ton small block- can it tow one?
have you never heard of draw tite weight distribution. Dramatically helps and load levels. It has a special hitch and 2 torque bars and the mount to put on the trailer. I have set up atlelast 30 of these on trucks, i could not imagine a 1/2 towing the trailer without it. Every trailer we sold where the guy had a half ton we installed weight distribution. Draw tite makes best kit and is very simple to install. Its around 200-400$ depending on the dealer. This way you will not look like an idiot towing your trailer.
Old Mar 22, 2004 | 01:32 AM
Trasher's Avatar
I was going to get that type of hitch also. They are great for any towing. I've used them before and it is amazing how they level everything out
Old Mar 29, 2004 | 02:32 PM
tta583's Avatar
I think it can but I don't know if you want to do it. I feel the same was echoed here. 20 to 22 foot of enclosed trailer is a nice sized sail to tow behind a smaller truck. Not to mention the wear on the trans and the bad milage when you load up a small gasser. I pull a 24" behind my SRW f350 Powerstroke (using a Weithgt Dist. hitch). When a semi goes blasting by I know its there, its not daunting by any means, but I know its there. I could easily get away with an f250 but the deal I got on the 350 was to good to pass up.
Here is a pic of the rig:
My Rig
BTW, Here are a couple of good sites for hitch parts. I have ordered from both, as have several friends, with no real problems. When I first needed to buy hitches and parts I did a lot of searching, these guys have the best prices I have been able to find. They are both the same shop, just different sites for the different lines.
http://www.drawtite-hitches.com/
http://www.reese-hitches.com/
As to weight distribution setups, if someone needs one I can pass along a name and number of a trailer builder in southern Indiana. I bought my enclosed from them. They buy a particular WD setup (I think it was a reese) by the 2 or 3 pallet lot. I could not beat their price even on the above sites. All it costs is a phone call to check them out.
Brent
Old Apr 13, 2004 | 05:42 PM
jcrawford1's Avatar
I just pulled a wellscargo 7x17 7ft tall enclosed trailer 400+ miles with my 2003 4.8 Chevy Ext Cab Silverado. A littler slower up hill I just dropped it in 3rd and motored on.
ReconBayou
Oct 31, 2022 05:37 PM
firsttimerider
Sep 26, 2015 01:49 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
