TUNDRA
With the Tundra you are going to be pretty limited on how large of a toy hauler you can pull. I would not look at anything with a dry weight over 4500lbs. By the time you load it with quads, gear, water, fuel, etc, you are probably going to be up around 6500lbs. 4500lb dry weight will limit you to about a 20-21ft hauler. Some of the lightest in that range are the Weekend Warrior Superlites and Skyline Rampage Waylite series. Both are great trailers.
ravencr
Nov 19, 2007 12:34 AM
