Harbor Freight Fold up 4x8 Trailers: WARNING!
#31
#32
I don't know much about Harbor Freight trailers but a lot of their tools are such cheap quality they should be considered disposable. If you want something you're going to use more than once or twice you're better off getting something better elsewhere. The trailers I saw there looked so cheap I don't care what they cost I wasn't getting one.
#33
I'm drawn to certain things they have. Generally speaking, most of it is bad, but they have a few good things in there.
The trailer is one of them, but with the disclaimer that is really only half finished, and for a hobbiest like me, works very well for heavier woodworking tool moving/purchasing and lumber purchases and means I don't need to buy a truck or a van.
It's kit like qualities have people making extraordinary good use of theirs, and a simple axle upgrade doubles the weight capacity and allows fancier wheels..
Welding the frame rigid is a huge upgrade. .
Not everyone's cup of tea when you can just buy a pre made one for considerably less time spent, but I've enjoyed making mine work.
Rob.
Rob.
#34
I wouldn't buy a trailer with 8" wheels anyway. They spin too fast and wear out the tires faster than bigger wheels. Hubs too I've heard. My 5'x8' tilt-bed has 12" wheels and that's the smallest I'll go. If I was shopping for a 2 or 3 place trailer I'd be looking for one with 15" wheels which are hard to find on smaller trailers.
#35
They have several 12" models, and some lighter 8's.
#36
I haven't seen the 12" wheeled trailers there but I haven't looked closely at them in years either. Back when I looked they had 8" wheeled trailers that looked like they were more suited for pulling around the yard than down a highway. They looked like they wouldn't hold up but apparently some do.
#37
As someone posted above the cheap trailers you can get from your local HF, or building supply place is a good little trailer for the hobbyist. The guy thats only going to use it once and a while. These trailers are not meant to be hauling quads and sxs all around the country. You want a good trailer and the only place to get those is a place that deales in trailers. Anything with smaller than a 14" tire should not even be taken out of town. These little 8, 10, and 12" tires heat up fast on the open road and blow apart. I see a dozen or so of those cheap trailers on the side of the road yearly
#38
#39
