Will this size tire fit without a lift?
Old Feb 6, 2005 | 07:00 PM
joechum's Avatar
Default Will this size tire fit without a lift?
Can i put a set of 33inch tires mounted on 15x10 inch wheels on my half ton silverado without putting a lift. If it will fit how bad will it scrub or will it at all.
Old Feb 6, 2005 | 09:04 PM
maddog56's Avatar
Depends on the year and body style of the truck, but normally 33" tires on 10" wide wheels are a little much for a 1/2 ton 4x4. If its a 4x2 then no way.
Old Feb 6, 2005 | 09:28 PM
firepitkeeper's Avatar
minor trimming is needed on K5 & K10 models ( lower rear edge or fender ) . Depending on shape of truck, tap lower edge in with hammer. only needs a little. My 02 silverado has 285's on stock alloys with no probs, but 10 inchers looks like you'll need to trim some plastic . not sure what offset is needed either. hope that helps ya some.
Old Feb 7, 2005 | 01:18 PM
DHV21's Avatar
joechum, what year is your truck.
I have a 97 Silverado 4x4 1/2 Ton and I was thinking of upgrading my tires from 265/75 R16 to the next size up a 285/75 R16 but I was told that I would need at least an 2.5inch lift for those tires to fit. I'm not actually sure what that size is in imperial. I thinking it's close to 33" tall & 12" wide.
Old Feb 10, 2005 | 07:29 PM
joechum's Avatar
mine is a 94 silverado a 285 (which is 32 inches tall) should fit on yours with no problem the might scrub a little it depends on how agressive tread you run
Old Feb 11, 2005 | 11:18 PM
DHV21's Avatar
I do plan to put a more aggresive tire on so I think it would be better if I did lift my truck first. Don't want to dammage anything.
Hankey Pankey
May 1, 2018 01:33 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
rcappie4
Jul 18, 2015 07:51 AM
