Bearing buddies?
Bearing buddies?
Hi, I was wondering if anyone out there could tell me, I have a trailer with dexter 3500 pound axles, what bearing buddies would I need? Also, I have the easy lube system, I have herd lots of good things and bad things about bearing buddies when using the e-z lube. Are they a good investment, or a bad idea? I haul my trailer alot, and I am super lazy, I don't like greasing the bearings all the time. Any input would be wonderful! Thanks everyone!
Bearing buddies?
I use bearing buddies on my two trailers ... one is now over 10 years old and has around 100,000 miles! I do change the bearings every other year and use mobil 1 syn red grease. I like bearing buddies ... i feel that there's a little pressure on the grease keeping the bearings wet and the hubs cooler. BUT don't think bearing buddies are any cause not to do maintanence! Bearings do fail, even if they have enough grease!
Bearing buddies?
Originally posted by: rescuediver
Now Bing, who would do something like that[img]i/expressions/face-icon-small-wink.gif[/img]
Originally posted by: Bing
they help on the smaller donut high rpm wheels,,,,,,especially when your going 90 for 5 hours with an overloaded trailer
Bearing buddies?
You are correct ... bearing buddies SHOULD NOT BE used on trailers with brakes. The grease is under pressure will leak pass the rear seal once it warms up ... with that said someone (can't remember where i saw them) makes an grease shield to help with this issue on boat trailers. Also helps if you don't over fill the bearings, lots of people like to pump and pump ... you grease gun WILL blow the rear seal out even if you don't have bearing buddies.
Bearing buddies?
Well, my trailer is equiped with e-z lube, so, if I pump and pump on my grease gun, I am just wasting grease cause it comes out the front. Problem is, I don't like to do it. I have to take the tires off so that I can pull that little beauty ring thing and pop off the cap in the center. Then I can grease. If I was to just not fill them all the way, would that work? Then the grease would have some place to go.
