Trailer floor coverings....
Trialer floor coverings....
I'm looking around trying to find something that I can put on the floor of my enclosed trailer to help protect the flooring and also looks good. I've looked a little into something like Rhino truck bed spray liners and thier competitors. So if any of you have done something like this or have an idea I would like to hear about it.
Thanks!
Thanks!
On my 7x14 enclosed trailer I installed the self adhesive vinyl floor tiles. They are 1 foot square tiles, I alternated black and white tiles for the checkered look. Installation was easy, did a light sanding, painted on this primer stuff made for adhesive tiles when used on porous surfaces such as plywood. You simply peel the backing off the tile and press it in place.
I have had this floor for over a year now. Some tiles have lifted up and sand has gotten under some. Gas that has leaked from the quads while trailers has caused some of the tiles edges to curl up. Some tiles have shifted slightly, while others have lifted up completely.
I am going to remove all the floor tiles and install a non slip rubberized epoxy similar to the pick up truck bed liner products. I'll let you know how it turns out
Non Slip Coating
Non Slip Coating
I put short nap marine carpet in my 7x16. It has a waterproof backing to protect the wood and it's cheap enough that I can replace it when it gets nasty. It was only $50 for enough carpet to do the whole trailer. For the ramp, I'm going to use a non-skid paint when the weather breaks.
I will be writing an article this spring about how to apply Herculiner to your trailer floor. It's less expensive than Rhino lining and you can install it yourself, at home, in a weekend.
Its been on the floor of the ATV Connection trailer for an entire summer and the stuff is tough as nails. What is really slick is I can raise the tongue jack until the floor is sloped and then spray the inside of the trailer with a hose to clean it!
I highly recommedn the Herculiner do-it-yourself solution!
ATV Connection Trailer Floor
Fake,
No, no waxing! This trailer is actually built by the amish in Indiana. The workmanship is immaculate and the attention to detail is superb. Its made by www.aluminumtrailer.com
I trust that you are being serious... and I am now more envious than before[img]i/expressions/face-icon-small-smile.gif[/img] Nothing like quality workmanship - IMHO. So any picts of the outside? My only issue is that I have a feeling that they would not approve of my choice of graphics [img]i/expressions/face-icon-small-wink.gif[/img]
http://www.fakeracing.com/galleries/...e-Racing-Rides
