Winter Ready How to
Old Nov 9, 2014 | 05:43 PM
DuneDragin's Avatar
Dune Rider
Which one of you is Pink?
Default Winter Ready How to
It's that time again.
I thought I'd post a general find on how to winterize, I'm sure there is much more that ATVC members can share.
We are draining and blowing out lines etc without running the pink anti-freeze thru the RV's and water equipped trailers.
seals are the concern at this point.
petroleum jelly
Old Nov 9, 2014 | 06:19 PM
DuneDragin's Avatar
Dune Rider
another find for active winterizing
Old Nov 9, 2014 | 07:17 PM
rider77's Avatar
Make sure to use the bio safe antifreeze. Knew a guy one time that just went down to Pep Boys and, well, you know what happened then...........
Don't forget to bypass the water heater and pop the drain plug! When I had my trailer I put a ball valve on the water heater drain so I could drain it after every use.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
byronman
Sep 6, 2015 06:34 PM
Sep 1, 2015 01:45 AM
