Trucks and Towing, All Makes and Models. Discussion on all makes and models of trucks and towing.
Ford Crew cabs w/7.3 Diesel
Old Aug 28, 2006 | 10:23 PM
  #11011
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Default Ford Crew cabs w/7.3 Diesel
My trailer already has a solar charging system, I better go see if its up to the task....
Old Aug 28, 2006 | 10:24 PM
  #11012
nedflanders's Avatar
naw, i don't think the brand matters as much as the warranty. i think mine are Bluestar. Check with your local battery guy.
Old Aug 28, 2006 | 10:36 PM
  #11013
KTM Patrol
Former Chinese POW!
Originally posted by: nedflanders
oh yeah, our Costco has 5-6 AMP solar panel set (made by Coleman), including regulator or controller (?), for $250 (US). The RV dealer wants $900-1,000 (cdn) for the same thing. It folds out into a triangle. it comes with battery cable clamps. just enuf to provide a useful charge. I think it's a 75Watt system. I KNOW it's around 5-7 amps DC. You really don't want any solar panel system that isn't going to create at least 5-6 amps charging. For your calculations, remember:
Amps X Volts= Watts. Well you know it's 12V, so if you have any of the other values, you can do the math and figure it out.
I have a Solar Boost 2000E, It says it has has output current rating of 20 amps.
Old Aug 28, 2006 | 11:09 PM
  #11014
WOW!! That's huge!!so 240Watts (at 12V). Ya, if ya left yer batteries charging on that unit, it might cook them pretty quick...UNLESS it has some features to go to trickle charge.
Old Aug 28, 2006 | 11:43 PM
  #11015
KTM Patrol
Former Chinese POW!
I havnt read it all but it seems to lower the charge as the batteries get more charged and you can set it to quit charging when you want to. It quits at 13.5 volts now. You monitor it with a LED readout. It seems to be very good at doing its job with my beat up 12 volt batteries.
Old Aug 29, 2006 | 03:59 AM
  #11016
BlackandRedWarrior's Avatar
Air Cooled Rider
Future Govenator of Kalifornia!
Originally posted by: mywifesquad
Originally posted by: rescuediver
Just be careful with the cheaper Kragen type of generators, they are NOISY!!! I know a couple people that have tried to quiet them down with no luck[img]i/expressions/face-icon-small-sad.gif[/img] Is your truck not wired to charge the batteries as your drive down the roadway? Mine will charge it as long as the key is in the accessory position. Wish it was like my Chevy though, as long as it was plugged in, it was charging the trailer batteries[img]i/expressions/face-icon-small-smile.gif[/img]
I stood next to one of these at the Jetmoto gathering at pismo in June. It was yellow and black and was around 3K watts and was fully caged/enclosed. It was around $319.00 on sale. We could carry on a conversation next to it and it was nothing compared to what was buzzing around at the time. Now you got me wondering how loud it would be in a quiet forest.
Since you are into imported things from Asian countries check at Kipor brand generators. They make an inverter generator that's on par with the Honda inverters, and gets good reviews as well. 3500 model is rated at 56-62dBA. Goes for about 1300 though. Which is like 1/2 what a Honda would set you back. Depends on if you want/need the A/C.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Aug 29, 2006 | 04:01 AM
  #11017
Air Cooled Rider
MWQ, without a doubt, the 2-6V are better. The batteries are rated on how long they last based on a 20 or 25 AMP draw. the 2-6V last something like 420 minutes. The BEST 12V deep cycle is about 160-180 minutes, so 2 of them would only give you 360 minutes, max. The 6V have bigger plates. You have to watch the water level on them. I found leaving ours plugged in all the time to the RV charging system would overcharge them and bring down the water level. so i just charge them as needed.
Ok Im convinced. Thanks! [img]i/expressions/face-icon-small-smile.gif[/img] Is there a certain brand/type I should look for?[/quote]
Trojan T5 is the "standard" pretty much. But I remember hearing a lot of people getting the Costco Kirkland brands for much less. I'd say check the "local" Costco or a battery dealer.
Old Aug 29, 2006 | 04:32 PM
  #11018
rescuediver's Avatar
Im still thinking about it. Im still wondering if 2 12 volts would be better than 2 6 volts. They are going to cost about the same.
I would think a good welder would be necessary for that kind of modification. how far back are you going to move it?
I am going to be either at home or the shop for most of the weekend. We can figure something out. [img]i/expressions/face-icon-small-smile.gif[/img]
I recommend the 2 6's[img]i/expressions/face-icon-small-wink.gif[/img]
From the looks of his previous jobs and recommendations from fellow customers I know, he is[img]i/expressions/face-icon-small-smile.gif[/img] The new 5th wheel pin box will be moving the king pin forward about 13 inches.
I am sure we can. Moving my brother's jeep to my house to help take off the rear axle[img]i/expressions/face-icon-small-sad.gif[/img] Not sure what is wrong, but he says that's what we need to do to replace the part that's broke[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 29, 2006 | 04:34 PM
  #11019
If not a fine[img]i/expressions/face-icon-small-blush.gif[/img] they might tell you to put a fence around your truck and not use it for 7 months out of the year[img]i/expressions/face-icon-small-shocked.gif[/img] so thesnowy plovers can have their mating season at your expense[img]i/expressions/face-icon-small-sad.gif[/img] again[img]i/expressions/face-icon-small-frown.gif[/img]
I have always wondered where the snowy plover mated for the 40 or so years the beach was open![img]i/expressions/face-icon-small-mad.gif[/img] Have I ever shared my dislike for envirinmental wackos before? [img]i/expressions/face-icon-small-frown.gif[/img]
I am sure we all have the same feelings[img]i/expressions/face-icon-small-blush.gif[/img] And yes you have[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 29, 2006 | 04:37 PM
  #11020
Hmm, see if you can find what the decibles are. I would think it'd be loud[img]i/expressions/face-icon-small-sad.gif[/img] Had a couple of friends that built wooden boxes around them and faced them away from the trailers at around 50 feet. Still loud in the forest[img]i/expressions/face-icon-small-sad.gif[/img] One even tried fabricating a new quieter muffler for it. Worked alright in the valley, but up in elevation, he had a heck of a time with it running[img]i/expressions/face-icon-small-sad.gif[/img] finally yanked the muffler off.
