Trucks and Towing, All Makes and Models. Discussion on all makes and models of trucks and towing.
→↑whats-wrong↓←
Old May 5, 2012 | 11:24 AM
TacticalRedneckofKentucky's Avatar
Default →↑whats-wrong↓←
I've got a problem with my new to me cummins.
Its a 95 2wd 12 valve 5 speed cummins, 4" straight pipe only mods. Newer head gasket, tires, clutch, and batteries.
Said it needed some o-rings replaced where fuel is seeping from the injector lines, seems to be around the head.. So i drove in a wet grassy feild last night, or 2 nights ago, started blowing whitish blueish smoke around 2000 rpms, they think it was cold start smoke, so today i go riding around, no smoke, let it idle for 10 minutes and it idled with little.. if any visible smoke.
So its leaking like crazy now, someone told me if there not sealed up, the injectors will allow oil to bypass and get into the cylinder and burn. I stopped to get fuel, checked the oil, and the level was under the halfway mark of unsafe... Bought some oil, drove home in a hurry, and there is oil everywhere on my motor (guess its been there a while, but i left a puddle at the gas station), it seems to be on the right side mainly, if looking at it from outside...
So boys, i would like this to get fixed. Any ideas.
Old May 5, 2012 | 03:22 PM
*correction; leaking from delivery valves
Old May 10, 2012 | 05:12 PM
put on bolts missing from injector pump, fixxed it, now oils coming from my dipstick?! crank pressure?
Old Jun 27, 2012 | 06:56 PM
hoytultratec's Avatar
Dodge Diesel - Diesel Truck Resource - Cummins - Home
hit these forums.
Old Jun 27, 2012 | 07:27 PM
dipstick was cracked, fixed with new dipstick from dodge, $70!
