which plow is the best-warn or cycle country
The CC is a very nice and sturdy plow. My 60" is significantly heavier/sturdier than the warn that came with Prairie $69 offer this year. I don't know if this is their standard plow or one made for that offer, but I would take the CC over it anyday.
If you want a heavy built blade go with a moose plow, if you want a lightly built blade go with Cycle Country. If you don't believe this find a deal that sells both and compare them!
I bought a 60" Warn this past winter and it worked really well on my Sportsman 600. I pushed a lot of deep, heavy snow without any problem. It goes on/off very easily...2 pins attach it to the mounting hardware. I also liked the fact that you get about 16" of ground clearance when raised to it's max height (using a winch). I didn't look at any other brands, so I can't say how the Warn compares. Whatever you get, I would highly recommend not getting anything smaller than 60". If you angle plow, the plow path will be narrower the quad so you end up driving on un-plowed snow. The 60" is just wide enough in the fully angled position, at least for the Sportsman.
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
