Eagle Plow
Old Nov 6, 2004 | 01:35 PM
Jackiespank's Avatar
Default Eagle Plow
Just bought an Eagle Plow from ShadeTree. The pictures in the directions are terrible. Does anyone have any advice to making this intallation a little easier on me? The written directions would appear to be OK but I'm not a nature with this stuff so i wish the pictures would have been better. Am i making too big a deal out of this? Any suggestions will be appreciated.
Old Nov 9, 2004 | 04:18 PM
Thunderbolt's Avatar
Default Eagle Plow
I have an Eagle plow on my Grizz and it was simple. Does yours have the two piece mounting plate ?? What problem are you having ?? I installed mine in less than an hour.
Old Nov 9, 2004 | 09:51 PM
Default Eagle Plow
Yes, a two piece mount. It's for my 2002 Foreman. I haven't even attempted it yet. Do need to stand it up or can I just put it on ramps. On second look the mount doesn't look like a major deal. Does the rest of it go together pretty easy also?
thanks,
Jack
Old Nov 10, 2004 | 08:34 AM
Default Eagle Plow
You should be able to do it on ramps with no problem. The only problem I had is on the push bar, The tabs with the springs that secure the push bar to the mounting plate wouldn't fit over the pins. I took a die grinder and slightly enlarged the hole and now the plow comes on an off in less than 5 minutes. When you go trail riding where ground clearance may be an issue, Loosen the four carriage bolts on the mounting bracket and slide it off.
Old Nov 11, 2004 | 07:36 PM
Default Eagle Plow
Thanks a lot. I have it on ramps in my garage and I have started it.
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
