Crossing Rivers- help!
Old Jan 14, 2005 | 03:07 PM
Pakrat's Avatar
Default Crossing Rivers- help!
Basically I ain't going anywhere unless I can cross rivers with my 3 yamaha atvs here in alaska. The 2005 Grizzly does great. The 2004 Bruin and 2004 Kodiak suck. After crossing 20-30 ft of deep water they suck so much water into the V belt case that they no go, obviously. Are there any modifications I can make? Also are there any modifications I can make to prevent the air filter box from filling with water? Suggestions appreciated, thanx!
Old Jan 15, 2005 | 10:12 AM
roscoe69's Avatar
looks like you will have to install a snorkel kit of some kind, probably rubber hose or plastic pipe.
Old Jan 15, 2005 | 10:15 AM
Chillin's Avatar
yeah a snorkle sounds llike what you need. If your going through really deep water you might want to think about relocating the rad..
Old Jan 16, 2005 | 03:17 AM
Outrage's Avatar
Pakrat,
Where are you from and where do you ride? I ride here in Alaska too. There are a few people I ride with that own Kodiaks & Bruins and they don't seem to have problems with their belts that I know of? I guess some kind of snorkel is a way to go but not sure it would be worth the work.
Old Jan 16, 2005 | 03:37 AM
Pakrat's Avatar
Ya I wouldn't have no problems with water in the belt if I'd stay the heck outa deep rivers. I live out in the valley on the Knik River, right on the river close to the bridge.
Old Jan 16, 2005 | 04:12 AM
Outrage's Avatar
Not a bad place to live because you can ride all the time. I live in Anchorage so I have to pack the ATV every time I want to ride.
Old Jan 16, 2005 | 04:14 AM
Gougeonit's Avatar
Pakrat, I was just looking around for some new ideas about a snorkel for my p650 and came across a complete kit for your bruin @ www.setxatv.com ...IMO it's pricy but it has everything you need. I found out on Thursday that my p650 can't swim as good as I thought, so when I get through pumping the water outta its lungs I will be doing both an intake and belt case snorkle.
Old Jan 16, 2005 | 04:24 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
a snorkel would be great,,,,sure
I would be sure all the plumbing for the belt cover breather is sealed properly also
Our scrammy had 2 sorry zip ties that failed us on the 1st fast puddle Julie found.
Old Jan 16, 2005 | 01:49 PM
Pakrat's Avatar
Thanks for the Link Gougeonit. They show all their parts and I shouldn't have no problem rounding them up myself cheaper. Going to put snorkles on my Bruin, Kodiak and Grizz before breakup. Then stick a snorkel on my head and I'll be all ready. I hate turning around because of rivers.
Old Jan 16, 2005 | 02:09 PM
DarkManX's Avatar
Snorkel kit Highlifter.com will help also buy some taller tires and a lift kit and add a tad more power to help them tires turn better
GOOD LUCK
as far as the belt gose i dont see why it would slip if the grizzily dosent
