Plowing Help
Old Feb 13, 2005 | 01:56 PM
Pakrat's Avatar
Default Plowing Help
Winchs and plows are sold by many different people on the net. The only problem you will have is that each brand of atv reguires a special winch mounting plate for that particular brand of atv. Installing a plate, winch and plow will require some mechanical appitude, but not a real lot. good luck!
Old Feb 14, 2005 | 12:38 AM
BryceGTX's Avatar
Good point Pakrat. But although a powered lift may be quite easy, the manual lift really is also quite easy. My blade weighs over 100 pounds. My manual lift raises the blade about 4 inches. The lift handle on my plow moves about 24 inches. That means I have a 6 to 1 leverage, or about a 16 pound pull. This seems pretty easy when I am using it. I have plowed for 3 hours at a time and never gottten tired from lifting. I think one advantage I see with the manual lift is that I have a feel for what the blade is doing. I am not saying the manual is best, only pointing out that its not so bad.
I hope this helps
BryceGTX
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
