4wd to 2wd adapter kit - Opinions?
Old Feb 1, 2005 | 02:56 AM
Springchinook's Avatar
Default 4wd to 2wd adapter kit - Opinions?
I have a 2004 Rancher ES 350 and a 2002 Rubicon. Any opinions out there about the pro's & con's of installing a 4wd to 2wd conversion kit? Appreciate any knowledgeable input. Would also like to know about difficulty of installation & cost. Thanks again!!!
Old Feb 1, 2005 | 08:59 AM
03250bayou's Avatar
if you buy the 4wd-2wd it'll be easier to steer, you'll feel like you've got more power...itll be alot more fun to drive. my friend put one on his wolverine and it was a whole new quad...it took them about 2 hours i think...they give u good instructions that say 2-4 hours installation time. you can pick up the warn kit for about $230 from www.4atvtires.com.
Old Feb 1, 2005 | 10:14 AM
95wolv's Avatar
Don't know if it will be much different from my installation on my Wolverine,had to pull some a-arm bolts to get at the differential to move it forward and pull the front driveshaft,but a couple of hours will usually get the job done. It is like a different quad in 2wd, turns much tighter, you can really spin the back and whip it around the corners, and feels more like a sport quad on the trail ,and if it gets rocky or deep, push the button, and you are back to 4wd, some of the best money I spent was on the Warn 424, hard to go wrong if you work and play on your quad.
Old Feb 5, 2005 | 01:03 PM
JTRider's Avatar
I own a '01 Rancher. I installed the Warn unlocker back last November. I've done alot of riding on my Rancher since then and I can say it was money well spent.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 5, 2005 | 10:58 PM
WolverineMan15666's Avatar
Yes! Its worth it. It won't tire you out as much in 2WD on those long all day rides. Get it, you'll like it.
Old Feb 7, 2005 | 01:50 PM
4xZuk's Avatar
Def. worth it! Why do you think most come w/ selectable 2/4wd from the factory?
franklyme
Oct 21, 2016 07:18 PM
Robinhood
Dec 26, 2015 10:28 AM
rgjackson
Sep 17, 2015 11:21 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
