Smallest CC 4x4
Old Feb 3, 2005 | 11:22 PM
BigBaller's Avatar
Default Smallest CC 4x4
What is the smallest cc 4x4, ever since I was really little, I wanted a 4x4 because I saw some one have alot of fun in the snow with it. LOL JW what is or WAS the smallest amount of cc in a 4x4, and wich moddel
Old Feb 3, 2005 | 11:37 PM
wyd's Avatar
wyd
I think a few companies use to make 250cc 4wd setups. Artic Cat is one and Polaris use to make a 250 2 stroke 4wd. These are the two that come to mind that I know of. Might be more but I'm unsure of others so someone else might be a few more.
Old Feb 3, 2005 | 11:58 PM
Coyotechaser's Avatar
Yamaha Timberwolf
Old Feb 4, 2005 | 11:17 PM
BigBaller's Avatar
It would be awsome if there was like a honda 90 with 4x4.
Old Feb 5, 2005 | 02:33 AM
ridinsmooth's Avatar
in my opinion anything under a 350 is too small of cc for 4x4
Old Feb 5, 2005 | 04:49 AM
lownrangr's Avatar
I have the arctic cat 250 4x4. Although it's primary use is my pit vehicle at my jet ski races, I have a plow on it and it pushes snow with no problem. I have had it in some mud and again it's done fine. You can always use more power though!!
Old Feb 5, 2005 | 04:24 PM
Specta's Avatar
A lot of people were hoping for 2005 Honda was going to offer a Recon 4x4.
Do they sell many Timerwolf 4x4?
Old Feb 5, 2005 | 09:47 PM
700vtwinman's Avatar
The smallest 4x4 atv currently being offered is the artic cat 250 manual 4x4 with H/L range. Polaris used to offer a 2-stroke 250 4x4, but I don't think they do anymore. As far as anything under 350cc being to small for a 4x4, that may be true for some applications, but if you are in 4x4 with the artic cat 250, you just run it in low range and you have plenty of power to use. And, one of the die-hard 4x4's out there has been the honda rancher 350......BUT IT IS REALLY A 300-325 RANGE MOTOR BECAUSE IT IS ONLY 329CC'S.
Old Feb 5, 2005 | 10:29 PM
Bear4570's Avatar
Actually the Arctic Cat 250 4X4 has a Hi/ Low/Superlow that will out grunt just about anything out there other than the AC 300 which has the same setup . The 2X4 has the Hi/Low range set up.
Old Feb 6, 2005 | 06:28 PM
4wheelerfred's Avatar
Suzuki made a quadrunner 250 4X4.
Robinhood
Dec 26, 2015 10:28 AM
mvwhite
Jul 29, 2015 03:32 AM
Riding Gear
Jul 7, 2015 05:03 AM
toonces
Jun 30, 2015 11:19 AM
WASCAL
Nov 27, 2003 12:55 AM
