Brake light kit???
Old Dec 24, 2005 | 12:27 PM
MrPlow2's Avatar
Default Brake light kit???
Does anyone know of a brake light kit for a 2002 Honda Rancher??
Old Dec 26, 2005 | 01:19 PM
MikeM's Avatar
hear that Honda Canada may have what you are looking for ($150 US !!)
Im going to try a K&S hydraulic brake light switch and wire it myself. There are other companies that make pressure switches that will work.
Montana Jacks also has a "Universal Stop Light Switch" that you can use on your foot brake
Old Dec 30, 2005 | 11:23 AM
gergb's Avatar
Here is a link, http://atvquadsquad.com/groupee/foru...664#4526015664 , to how I add brake lights to my Honda ATV's.(including my brothers 2001 Rancher) Hope this helps.
Old Jan 4, 2006 | 02:52 PM
action450s's Avatar
Nice thing about the honda kit is that it gives you the nice factory switches that they use on the newer bikes with factory brake lights for a nice clean install with out modifying any hydraulic lines for pressure switches.
Old Jan 5, 2006 | 09:46 AM
gergb's Avatar
My setup uses the same factory switches that come with the factory kit, I bought them from Honda. I just used different lights, and made my own wiring harness. You can buy each part in the kit as seperate pieces from Honda. The part numbers are listed in the link.
Old Jan 11, 2006 | 06:54 PM
MikeM's Avatar
I was not as comfortable with an aftermarket hydraulic switch, probably why I was procrastinating. I didn't want to tap into the start in gear wire either.
But I just got lucky and picked up a factory kit from a dealer in Quebec for $41 US!! Patience paid off this time.
Cummins Driver
Sep 11, 2019 01:22 PM
sweaver
11
Aug 18, 2015 03:47 PM
DeFox500
Jul 26, 2015 06:32 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
