Tug of war
Old Mar 6, 2006 | 07:52 PM
  #21
v2rider's Avatar
Default Tug of war
Originally posted by: trvman
some great atv's but only one comes with an 2 inch recever hitch that is designed to pull with just putting a ball on a bike and pulling is not the best way to pull and cc's make a huge diffrence.
The AC's come with a 2" receiver hitch
Old Mar 6, 2006 | 11:19 PM
  #22
tyler711's Avatar
Default Tug of war
The manufacturer's towing numbers are pretty useless -- they are not so much what the quad can pull, but what it can stop and control. I'd bed that most utility 4x4's would have no problem getting a several thousand pound trailer moving (done it myself with my little 400), but when you try to stop, all four tires just skid. When turning, the back of the quad just gets pushed out from behind you.
The Polaris has the highest recommended towing weight because it is the heaviest quad, and can therefore hold its own against a heavier pushing on it.
As for all out pulling, those numbers mean very little.
In terms of a tug of war, the issue is traction, not power. Once a quad gets all four tires spinning (on some quads 3, which is a disadvantage) the only difference in the quads is traction between the tire and the ground. THis is increased by better tires and more weight. I'd say just about any utility 4x4 these days can spin all four tires, so the issue is then weight and tires.
Old Mar 7, 2006 | 08:59 AM
  #23
ppope's Avatar
Default Tug of war
Tyler711,
You just duplicated what I have been saying the whole time. Weight, tires/traction, gearing. Polaris has the best in all three of these categories. This topic keeps going in circles and posts keep getting replicated.
Old Mar 7, 2006 | 12:37 PM
  #24
wideopenrider's Avatar
Default Tug of war
Yes i'm sure polaris will win in a PULL OUT.
This tugof war thing you people are talking about is rediculus. Usually either wheeler moves and both riders get pelted with rocks and gravel.
But yeah, if you hook to a sled, polaris will probalby win all the way because of the weight. Their boat anchors.
Old Mar 7, 2006 | 12:39 PM
  #25
Default Tug of war
U guys wanna see some wheelers pick and scratch for traction?
Hook them up on dirt pulling front to front. Talk about dig. So much weight gets transfered to the front tires its insane!!!
ANd when they start to get loose and slide back and forth it gets fun real quick.
Old Mar 7, 2006 | 07:11 PM
  #26
v2rider's Avatar
Default Tug of war
Originally posted by: ppope
Tyler711,
Arent Arctic Cats about as heavy, and Im confused about Polaris winning the "tires/traction" category. Anyone can put a better tire on there quad and have just as much traction as the other guy.
Old Mar 7, 2006 | 08:08 PM
  #27
ppope's Avatar
Default Tug of war
V2rider,
let me clear this up for you. This topic is about stock machines, just as they are on the show room floor, as stated in the very first post. Sorry, but polaris has better stock tires the Arctic Cat for pulling or mudding. If you put better tires on it, it is no longer stock. As for the weight they're close but the popo has it a little, however, the gearing on the popo is lower than the cat.
Old Mar 7, 2006 | 08:30 PM
  #28
v2rider's Avatar
Default Tug of war
I think the tire thing is all opinion. I have Goodyear MT/R Radial tires, that came stock. My buddys 06 sportsman 700 seems to get stuck more than i do, more so in the snow, which he blames on polaris having crappy tires, and mine being better. So i assume its all a matter of opinion . But thanx for clearing that up for me
Old Mar 7, 2006 | 08:47 PM
  #29
MikeM's Avatar
Default Tug of war
hey ppope, are you talking about the PXTs on the Polaris?
Old Mar 8, 2006 | 12:32 PM
  #30
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Default Tug of war
V2rider,
I didn't know Polaris's were geared so low, what is the ratio? Would the 500SP be geared even lower then the 500 AC manual in low range and 1st gear? Final drive on the AC's is 3.6:1 on some and 4.0:1 on others.
