NO Oil!!
Old Sep 11, 2006 | 11:32 PM
v2rider's Avatar
Default NO Oil!!
Catterman flushes his out with water[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 12, 2006 | 04:40 AM
BigOne's Avatar
Default NO Oil!!
I use an industrial degreaser and then ride it around for 5 minutes and then put the oil in.
Worked good for the first minute. LOL
Old Sep 12, 2006 | 09:14 AM
scootergptx's Avatar
Supersock
Hired Gun!
Default NO Oil!!
Originally posted by: Catterman
You are 100% fine.
Stick to the point C, he wants to know about the oil situation. [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Sep 12, 2006 | 01:47 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Default NO Oil!!
You are 100% fine.
Oh ya, then your engine is good still [img]i/expressions/face-icon-small-happy.gif[/img]
  #15
Catterman's Avatar
Got Milk!
Default NO Oil!!
I have done this once and it actually didn't turn out too good [img]i/expressions/face-icon-small-sad.gif[/img] I DO NOT recommend the water method [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 27, 2006 | 09:33 PM
  #16
HCFirefighter82's Avatar
Default NO Oil!!
Oil? I ride a Honda..we dont need no stinkin oil!! haha
Old Oct 28, 2006 | 12:19 AM
  #17
Hebs's Avatar
Default NO Oil!!
the viscosity breakdown of oil takes a long time. I'm assuming you change it at the correct intervals. You're engine will still be plenty lubed, and 10 seconds isn't even close to being long enough for the oil to heat up and thin out.
Old Oct 30, 2006 | 07:03 PM
  #18
montyh's Avatar
Default NO Oil!!
i would fill it with oil and crank it with the kill switch off until the oil pressure light goes off. this should prevent anything from happening to the engine while the filter is filling and the engine is getting oil. this will take a few seconds. otherwise, you will have a few more seconds of running without oil while the filter is filling ect...
monty
Old Oct 30, 2006 | 08:15 PM
  #19
Williebee's Avatar
Default NO Oil!!
If this ever happen's to anyone again ,after you put the drain plug back in refill the sump ; then remove the spark plug an add a table spoon of oil in the cylinder and turn the engine over a few revolutions with the spark plug out . Install spark plug and you're good to go , that's the way i do lawn and garden equiptment engine's when servicing them ! ...................williebee
Old Oct 31, 2006 | 11:23 AM
  #20
zorro700's Avatar
Default NO Oil!!
Yeah, your right. Honda's don't PERFORM high enough to create friction. lol
