Bear Claw tire pressure? Which way to run the tread? 22X12X8 on a Z400?
Old Oct 8, 2006 | 10:48 AM
bananaman's Avatar
Default Bear Claw tire pressure? Which way to run the tread? 22X12X8 on a Z400?
Mostly sand, some jumps, and trails, but sometimes thick mud gets in the way. What pressure r u running? Do they really hook up better in the sand running them backwards? What does that do for the mud traction? Which way do you run the tread?
Old Oct 10, 2006 | 11:29 PM
magnumLover's Avatar
dont run them backwards, they are designed to run the right way.
it should say what way to put them on. I am not very sure about the tire pressure though.
Old Oct 12, 2006 | 06:53 PM
bananaman's Avatar
Yeah, I mounted them the way they said to. How much pressure? It says 7lbs, but on this one, I have to deviate. At 7psi they are hard as a rock.
Old Oct 13, 2006 | 10:13 AM
Argyll's Avatar
I run about 5.5 to 6 PSI in the Wetlands I have (which btw are radials). I know they're not the same tire as the Bearclaws, but they also say to run 7 PSI. It won't hurt to lower the PSI on your tires a bit. Try starting at 5 PSI. I wouldn't run any lower than 4 though (could run the risk of bent rims the lower you go), but just experiment and see which works best for you.
STLyamwar
Jul 25, 2020 04:44 AM
mtdewmn
Jan 19, 2017 12:13 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
