how often do you change your spark plug??
Old Mar 6, 2007 | 07:40 PM
upnort's Avatar
Default how often do you change your spark plug??
Change then??????
I guess if were acting up but probably clean it first.
Old Mar 6, 2007 | 08:37 PM
Wolvydude's Avatar
Originally posted by: Shootecogo
I have a '95 Honda 300 in the family that is still on the original plug with at least 10,000 miles on it. Don't fix whats not broken.
Agreed. I'm still on my original plug and won't change it unless it gives me a reason to.
Old Mar 7, 2007 | 07:14 PM
oldturtle's Avatar
Lots of bad info on this item. Do not wait until you have a problem. If you do then there is good chance that plug will need changing just when motor is covered with mud and you will probably get dirt and mud in motor. So replace plug about once a year before needed and replace at home after a thorough cleaning. Plugs are cheap. Rebuilding top end because of mud and debris in motor is not.
Old Mar 7, 2007 | 07:57 PM
Wolvydude's Avatar
So I should replace a perfectly functioning part simply because it MIGHT fail when there MIGHT be dirt present? It's an atv, I expect there is going to be dirt somewhere on the machine at all times. I can think of a lot of reasons to change a plug, but paranoia isn't one of them. I'm a mechanic by trade, and I sincerely wish more people thought like you. I could make a killing changing out perfectly good parts. No problems to diagnose, just a little paranoia on part of the owner. Whatever helps him/her sleep at night works for me. I could retire early, real early.....
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
