Backfiring Question
Old Jun 23, 2007 | 06:26 PM
acpower's Avatar
Default Backfiring Question
A. What causes backfiring?
and B. Why is my ATV backfiring?
Thanks.
Old Jun 23, 2007 | 09:56 PM
buckaroo50's Avatar
When the air/fuel goes lean for a number of reasons such as getting water in the gas etc.
If it backfires when you let off the throttle then this is why,
1) When the throttle valve is in the idle position, fuel does not flow out of the main system (needle, needle jet, main jet). Fuel is only delivered to the engine by the pilot (idle) system.
2) The combined effect of the closed throttle and elevated engine rpm is to create a fairly strong vacuum in the intake manifold. This vacuum, in turn, causes a high air flow rate through the small gap formed by the throttle valve and carburetor throat.
3) Under these conditions the pilot (idle) system cannot deliver enough fuel to create a normal, combustible air/fuel ratio. The mixture becomes too lean to burn reliably in the combustion chamber. It gets sent into the exhaust system unburned and collects there.
4) When the odd firing of the lean mixture does occur, it is sent, still burning, into the exhaust system where it sometimes ignites the raw mixture that has collected ---- the exhaust then pops or backfires.
Old Jun 23, 2007 | 11:33 PM
acpower's Avatar
it is backfiring when i let off the throttle. is it bad for the machine and needs to be fixed or is it normal? thanks.
Old Jun 24, 2007 | 02:13 AM
buckaroo50's Avatar
Yes it is bad for the machine.. Popping is ok and possibly a rare backfire.
You probably need only to make the pilot jet setting a little more rich.
fordfaithful21
Dec 7, 2015 05:52 PM
Bigtwin700
Sep 9, 2015 09:32 AM
black798
Sep 9, 2015 07:42 AM
Rooky
Sep 9, 2015 03:16 AM
Brandon400
Sep 7, 2015 12:20 PM
