Any mudder out there?
Old May 4, 2009 | 04:43 PM
  #21
hoytultratec's Avatar
your hensim with a yamaha engine is just a clone yamaha engine im betting and as far as a belt slipping in water there are plenty of belt drive atv that go through water without problems including mine.
and as far as holding up to abuse any name brand atv with belt drive will hold up better then your hensim.
Old May 6, 2009 | 01:04 AM
  #22
SpiritOne's Avatar
otherwise, if your dead set against a belt, Hondas are all shaft driven. That comes with its own set of positives and negatives.
Old May 13, 2009 | 09:39 AM
  #23
Tadpole II's Avatar
Can you give us some of the positives and negatives of shaft driven Hondas? I bought an '08 rancher 4x4, and need to know some possible problems with these machines.
Old May 13, 2009 | 10:11 AM
  #24
Turfguy's Avatar
If its the ES Rancher, you may eventually have problems with it shifting. It usually is something cheap, just a pain. I own an ES that my wife drives and have not had problems yet, but I know eventually i probably will.
I think the Honda reliability is unmatched, so i don't foresee you having any major issues. Enjoy the new ride.
Old May 13, 2009 | 02:23 PM
  #25
emmittman's Avatar
so i want to sell my hemsin 400 and get something with more power. What quads have a diff lock for the front and or rear? I heard the Polaris' will spin both front tires stock. is that true? Would a Polaris 500 have enough power to spin a set of oversized tires? I want a quad for the sole purpose of mudding. Anyway, hit me back
Old May 13, 2009 | 04:13 PM
  #26
SuziOzark's Avatar
Old May 13, 2009 | 06:47 PM
  #27
emmittman's Avatar
huh?
Old May 15, 2009 | 06:46 PM
  #28
importatv's Avatar
ITPs Great Stuff
Old May 17, 2009 | 06:59 PM
  #29
JDSpud's Avatar
Yea polaris has front diff lock stock completely automatic no buttons or levers to mess with. I know where you are coming from with your feelings on the wet belt fear. My belt has never been wet but ive seen plenty of them get wet and slip. Not too big a deal to dry out. and hey replacing a weak or burned belt sure is alot cheaper and easyier than fixing a broke trans shaft or gears, watever other quads weak point is.
Old May 31, 2009 | 06:12 PM
  #30
Schickie's Avatar
'02 Foreman 450 with 27" 589's
