Snowplowing hints or techniques wanted.
Old Dec 18, 1999 | 10:15 PM
  #21
mxer's Avatar
If i am helping people out plowing, will the cops bother me if i go on the road to get to the peoples houses?
matt
Old Dec 18, 1999 | 10:56 PM
  #22
SCman's Avatar
Ok Max6x6, I'm gonna let you have your due just this once. That is indeed a nice setup, because it specifically suits its purpose. And you did not include a bunch of propoganda with it.
Old Dec 28, 1999 | 04:09 PM
  #23
TRX400EXitement's Avatar
Here are a few plowing tips:
1. The plow skids help to prevent plowing gravel with the snow
2. If you have ice under the snow the plow can spin you around when you hit big snow banks
3. If you are going to get a big snow storm you can plow twice, over 8" you can get stuck easy, although you can get through 2' banks if you hit them enough
4. You can turn up the tention on the trip springs for plowing gravel
5. If you have a lot of hard packed snow and ice on your driveway you can take the skids off to get a better bite
Old Dec 28, 1999 | 10:13 PM
  #24
dand11's Avatar
Ok it is stupid question time. Is it worth the time to put a plow on a 2X4 machine? I have a Polaris 325 mag. I have pushed snow with a garden tractor with good results but was wondering if extra weight and chains would be enough. How do the 4X4 machines do with the front wheels turned off?
Thanks
Dan Daugherty
Old Dec 28, 1999 | 11:15 PM
  #25
Bill.Ciliberti's Avatar
DAN,a 2x4 quad would be ok as long as you had REAR chains.It would be just like a garden tractor but much quicker and efficient.Im telling you to ''GO FOR IT'' you wont be disappointed.My Sportsman pushes up to 6 inches of snow pretty good without the AWD on.I think my Mudrunners hav alot to do with that though.I use NO chains at all. GOOD LUCK=====BILL
Old Dec 29, 1999 | 09:20 AM
  #26
Brian_Kimmel's Avatar
I have a 97 Yamaha Timberwolf 2x4 with a 50" Moose plow and it works great. I use it to plow my 1/8 mile long gravel driveway. I just put a couple sand bags on the rear rack for added traction and it goes great. I'm sure with chains it would do even better. So I would say go for it.
Old Dec 29, 1999 | 10:40 AM
  #27
Sneekypete's Avatar
Dand11 I just plowed 6" of snow with my SP500 yesterday. Didn't need to use 4x4 at all except on one hill which was fairly steep. I plowed over two miles of private gravel road and several driveways. No chains on the rear tires either. Can't see that you would have a problem. Go for it. BTW, if you catch it early enough, you get to do it twice.
Sneeky
[This message has been edited by Sneekypete (edited 12-29-1999).]
Old Dec 29, 1999 | 07:39 PM
  #28
Aniel's Avatar
That's sneeky
99' SP500
Old Dec 31, 1999 | 08:46 PM
  #29
honda_450es's Avatar
Here's what I've learned from plowing snow with an ATV. I have a 450ES witha Moose 50" plow, and use a winch to raise and lower it.
1. Chains- Don't use them unless you have ice under the snow. They tend to dig into lawns, leave scratches on concrete, and bite into asphalt.
2. Weight- Only put weight on the back rack. You already have plenty of weight on the front with a blade. I use a couple of sand tubes on the rear rack.
3. Skid pads- Use them all the time, unless you're going to always be on perfectly flat concrete surfaces. They hold the blade up just enough to get over small bumps and humps that would otherwise make your blade spring forward. They also keep the wear bar wear to a minimum. Pads are cheap to replace.
4. Side markers- Unless you're inside a cab enclosure that limits your vision, you should easily be able to see the edges of the blade. You can usually lean out far enough to see what you need to see.
In real deep snow, make the first pass with the blade up, to knock it down to a more manageable depth. Once you make the first pass, you can "nibble" away at the what's left. A strip of rubber along the top of the blade really helps in keeping the snow in front of you and not blowing up in your face.
Not claiming to be an authority, just have experience. Feel free to email with any questions.
Old Jan 20, 2000 | 07:29 PM
  #30
st22's Avatar
where did you get your Moose plow and how much did it cost?
