Dragging logs?
Old Nov 29, 2010 | 07:02 PM
Kellem's Avatar
Default Dragging logs?
Kind of a simple question here but was wondering which is better if better applies.
Is it better to drag a log backing up using the winch hook with tow strap or going foward with the strap hooked on the hitch ball?.
I recently bought a 700 KQ and been using it for cutting wood.It does great at dragging reasonable size logs,just wondering if the 2500 Warn winch housing could handle repeated stress.
Thanks
Old Nov 29, 2010 | 07:08 PM
faruquehabib's Avatar
been making wood myself lately (outdoor burner), i drag logs from the hitch with chains with the rubicon, works perfect, and is easier to drive.
Old Nov 29, 2010 | 11:12 PM
user493's Avatar
Moto Psycho
You're never supposed to use the winch for towing anything.
Old Nov 29, 2010 | 11:22 PM
DODGE57HEMI's Avatar
Mopar Man!
X2 Use the hitch as it is the sturdiest lowest center point of gravity on the bike therefore giving you the strongest most powerful part of the bike to tow with.
Old Nov 30, 2010 | 07:17 AM
papahouse's Avatar
I always use the hitch
Old Nov 30, 2010 | 07:18 AM
Kellem's Avatar
Thanks.......Now i know.
Old Dec 15, 2010 | 08:08 PM
vinny04's Avatar
Old Dec 16, 2010 | 07:59 AM
It depends on how far you're going to move the wood in my mind. If less than 100 feet or so I'd back up attaching the strap or cable to a good hard point. This helps you see if the log is going to get caught or not. If going a good distance it's good to attach to a hitch although I wouldn't use the ball if possible. They can break off with a good enough sudden shock but probably wouldn't. The best way is to get the log off the ground like Vinny showed or use some kind of wheeled rig to keep the butt of the log from digging in. Here's how we were doing the first way. YouTube - Skidder, skidder, I don't need no skidder
Old Dec 27, 2010 | 09:33 AM
JeffinTD's Avatar
Yeah, the gears in a winch aren't designed for a shock load. If while dragging the log with the winch line it tumbles or snags on something and the line goes slack and snaps tight you can break a lot of gears in the winch.
I've used a tow strap to my front bumper when I need to drag something out of the trail or whatever.
bmxatv10
Oct 14, 2022 06:23 PM
Honski250r
Sep 26, 2015 09:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
Elkaholic
Sep 6, 2015 02:44 PM
