Yamaha Grizzly 700 EFI help
Old Sep 1, 2014 | 06:02 PM
chance536's Avatar
Default Yamaha Grizzly 700 EFI help
I was riding it on the road and I gunned it. Speedometer read 90 though I'm positive it's inaccurate. Check engine light is off but it sounds different rides just fine. Kinda roars a bit when your slowing down. The normal engine sound not the whine sounds a bit louder. I'm kinda worried because I can't pay much to fix it.
Old Sep 2, 2014 | 08:32 AM
RedRocket204's Avatar
Assuming you are referring to the 90 as mile per hour? Are you sure the POD is not set to KPH? If so, turn off the ATV, press and hold the Select button on the POD and turn on the ATV, release the button.
I had my POD recently revert to KPH because of a stator charging problem where my battery was depleted. Now to get the stator replaced and oil-line update.
Old Sep 2, 2014 | 03:53 PM
user493's Avatar
Moto Psycho
You could be right. 90 kph would be 56 mph which is a realistic speed.
2quiker
Mar 22, 2022 08:36 PM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
