Silver Lake question
#15
Yeah I had the same problem, I stuck a couple of layers of window screening in the end of my silencer cap on my Big Gun. When they have young girls checking the gate to the sand entrance, you can usually get away with it. But the real rangers spotted it in a second. So I just walked up to David Allen Racing AKA Duneland at the end of the parking lot. Fifteen bucks and I had a SA. You also have to wear a helmet. No booze, etc... this months' issue of dirtwheels does a rundown on Michigan ride areas and lists everything for Silver Lake.
There are tons of things to do there, if not just relax on the beach. Take the fam, they'll have a blast!!!
#17
most of the shops around there sell flags, they are a little more $ at the shop right next to the dunes. IF you get one at david allen racing the white ones are cheaper for some reason. If you go when it is busy, you may not get in the parkling lot, they have a voucher system, what they really need is a bigger parking lot.
I Was the one that started this post last year, I took my family several times last year, there is plenty of things to do in the area.
To be on the safe side, I would find a SA for your quad, just incase a home made one won't pass. I have the disc system on mine, they never even stop mine, even though it is loud.
#19
I don't think you can get the disc system with your type of pipe, maybe some one will answer that. But discs replace the end cap, the more discs the better the flow, if it is to loud to get in, take some discs out,,then add more once you are in the dunes once you are checked..
I would call David Allen racing (right next to the dunes) and see if they have a SA for your system, but first try a home made one, if that don't work, go across the street and buy one.
