glamis
Old Nov 23, 2007 | 12:39 AM
raptorSE's Avatar
Default glamis
i posted this is other tire and drivetrain topic but nothing and i know somebody might be able to help
i just got some skat trak hauler tires, ive never had paddle tires before and i know ALOT of you have had them and know alot about them.
1..whats a good psi to put in them (hard or soft)
2..does it make a difference (my dealer put them on rims) if you look directly from rearend at them they are not identical like a paddle width difference.. would this matter? hard to explain like the tire is turned forward on one rim like 1-2 inchs
3..tried for about 5 hours to do a decent launch (raptor 700r) cant get hang of it would i need different sprockets? or front rear ?
Old Nov 23, 2007 | 11:01 PM
MNRAP's Avatar
Default glamis
<div class="FTQUOTE"><begin quote>Originally posted by: raptorSE
pressure variances will change how easy the tire spins. I've run anywhere
from 2lb to 7lbs depending on sand conditions and what I'm doing with the quad.
2lb for sand drags.. 7 lbs allow more sliding while duning.
you can line them up by removing the hub collar and replacing it a spline or two to the direction it is off to synch it up with the other tire.
try different pressure in the tires.. more to get them to spin easier.
</end quote></div>
Old Nov 23, 2007 | 11:41 PM
raptorSE's Avatar
Default glamis
well somebody posted in my other thread goto that its more geared to tires not where to ride...
RoostKing
Oct 16, 2000 12:28 PM
Calvin
Oct 11, 2000 02:44 PM
Mike Frey
Where to Ride
Feb 14, 2000 12:11 AM
