my deepest, but didn't get stuck
Hebs,
Thanks for the info. Okay so the PICS above in that type of situation you should run more air right? For deep mudd'n in soupy swampy muskeg marshy slop, should I have my PSI as inflated as high as possible? Thanks, R' |
My 800 Sportsman is a heavy utility Quad like around 760 lbs plus my 350 lbs.
to boot! R' |
That's basically a creek bed that he's driving thru. Air isn't really a factor as long as there's firm ground on the bottom. (unless he wants to do water wheelies or float with the help of basket balls and such) I usually run about 6lbs in my tires. Not too low that the bead doesn't break easily... (had it happen before, what a day ruiner) And not too high that I lose traction. (I ride where I need the flex of the tire to grip) Some people run 8lbs up front and 6 in the rear for stability, (body roll) but those guys mostly ride trails... IMHO, you should be running between 6-7lbs on your PoPo when you're mudding...
Wow, that's CRAZY !!!! LOL[img]i/expressions/face-icon-small-shocked.gif[/img]
Thanks Hebs for the info. okay between 1 to 2 more PSI
in my tires. Okay got it! Whats crazy Brnxadk? R' |
Those pics r crazy!!
those carlisles are radials. I used to run 20 to 25 in the front and 5 to 10 in the back. Hard tires are nasty in the mud. Keep the back a little lower because you want the back to drop and the front to come up and the back will grab nice.
didnt get stuck eh.. sweet
dang that's deep it's a good thing you had a snorkle
