Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Rhino winch wiring?
Old Dec 11, 2007 | 10:03 AM
06450Rhino's Avatar
Default Rhino winch wiring?
When installing winch wiring, do you need to splice onto the ignition hot wire or is there an accessory plug that doesn't require splicing? I don't want the winch power on all the time only when the ignition is on. Please help!
Old Dec 14, 2007 | 01:24 AM
HeftyLefty's Avatar
Can you read a volt meter?. If you can, and you have one; check your fuse box for a circuit that is hot when the key is on, and dead when it is off. You can tap into that fuse without splicing wires, just go to RadioShack and get some fuse taps to fit your fuses. They slip over the fuse and give you a hot tap out. Use a fuse rated as high as the contactor.
Wire the contactor hot side to that tap, waterproof it; ground the contactor good, and wire the winch straight to the battery; and you should be good to go.
HTH
Old Dec 14, 2007 | 08:36 AM
06450Rhino's Avatar
Thanks, I'll try that.
toonces
Oct 19, 2015 02:21 AM
MNatv89
Aug 10, 2015 02:20 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
