Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Running wires for auxiliary lighting
Old Mar 31, 2008 | 09:47 PM
Thevolkp's Avatar
Default Running wires for auxiliary lighting
I'm leaning towards adding 2 lights, one on each side of the front cage above the side view mirrors. Do you normally run the wires down the outside of the cage tube or drill a hole and run them on the inside of the tubes?
Old Apr 1, 2008 | 04:34 PM
Rudedog's Avatar
Inside the cage.. Yes, drill a hole and route through the tubing. Be sure to put rubber gromments at each hole (entry & exit). Most of the time you can take nylon twine, put it in one hole, then use a vacuum to draw (suck) it to the other hole/end. Then use good tape to secure the wires to the twine and pull it back the other way.. Wha-la!
Rude Dog
SOLOLUCKY
Oct 4, 2024 09:09 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
FWhitt
Jun 13, 2015 02:22 PM
wildbill59
Jun 9, 2015 02:28 AM
