Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Synthetic oil for the motor and diff.
Old 10-06-2008 | 09:07 PM
Scates's Avatar
Default Synthetic oil for the motor and diff.
Does anyone have information or experiece with running Synthetic oils in Rhino motors and differintals? What type of oil? Motorcycle type (for wet clutches) or automotive type. Thanks for any info guys...
Old 10-21-2008 | 09:18 AM
prowrench's Avatar
I have been running Amsoil in mine since new, it's wet clutch compatible and I use Purolator Oil Filters, best filter made and much cheaper than the OEM filter. I use Amsoil Gear lube in my differentials. over 3 years & 2000 miles with no problems.
I know many will disagree but automotive oils are not formulated for the gears and clutch ATV & Bike engines have.
Happy trails.
Old 10-21-2008 | 04:36 PM
Scates's Avatar
Thanks that helps, I assume Amsoil is synthetic.
Old 10-21-2008 | 05:18 PM
TLC's Avatar
TLC
Yes Amsoil is 100% synthetic. Not sure why it would matter even if the the oil was not meant for wet clutches on a CVT machine that has no wet clutches anyways.
Old 01-07-2009 | 04:45 PM
UGLY88's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: prowrench
Happy trails.</end quote></div>
What is the part number of the Purolater filter?
Old 03-31-2009 | 09:47 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I don't usually come to this forum, but I saw your post in passing....
I highly recommend Maxima's synthetic oils: Extra or Ultra. They are ester based and rated API SG/JASO MA. Ultra is Extra with the addition of a synthetic friction modifier and comes in some unconventional weights.
If you want a performance oil and are willing to embrace the ultimate in current oil technology, then I would recommend Redline, or in cold weather Maxima 530MX. Both these oils are ester based.
One note....don't be scared off by the fact that Redline is JASO MB. It contains a new generation of organic friction modifiers, yet is still wet clutch safe. JASO has no category to rate these wet clutch safe modifiers, so they have to call it MB (your owner's manual will probably say MA). Because of all the friction reduction, I am seeing a (torque/horsepower) increase running Redline....it's the real deal! I am running it in all of my 7 quads (including the ones with autoclutches and centrifugal clutches), and my clutches are excellent.
I don't know what your owner's manual specs, but in my diffs I run Maxima 75W90 Synthetic Gear oil.
http://www.redlineoil.com/products_m...?categoryID=11
http://www.maximausa.com/
EIF
04-20-2017 08:15 PM
mrtidy
02-03-2016 06:00 PM
kodiacrunner
10-04-2015 12:52 PM
Whitelx1
10-02-2015 11:55 PM
maveikfe
1) Engine problems..
09-24-2015 11:36 PM
Quick Reply: Synthetic oil for the motor and diff.
