Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
oil in air box
Old Dec 31, 2008 | 05:14 PM
crazy_Rhino_ride's Avatar
Default oil in air box
my Rhino 660 uses a little oil and when I take the air filter out there is always oil in the box, I think it is coming from the cranck breather tha tconects to the top of the box.
Old Dec 31, 2008 | 09:30 PM
pwillie's Avatar
Keep me posted,because I have been smelling oil when I run mine...
Old Dec 31, 2008 | 09:32 PM
I will if any one will talk, nead help Please
Old Jan 1, 2009 | 05:24 PM
pwillie's Avatar
Give them about six monthes,then some one will tell you how dumb you are for not taking it to a dealerHAaaaaaaHAaaaaaaaaaaaaaaaaaaHAaaaaaaaaaaaaa
Old Jan 17, 2009 | 11:56 AM
RaptorOwner's Avatar
I have found this when I was climbing a steep hill or getting on the gas when sideways. One of my buddies was riding in a bowl at Dumont and got quite a bit sideways and it shot out a lot of black smoke and it stopped. We took it all apart and the whole airbox was filled with oil. Some say its blow by from the compression side of the Piston meaning your rings may need to be changed.
Old Feb 2, 2009 | 04:53 PM
Olorin's Avatar
This same thing was happening to someone I know... the machine ended up dying, and he had to have the top end rebuilt. I know he rode it real hard and didnt have it regularly serviced. So, a top end gasket kit, a used cylinder and piston etc, 6 hours of shop time and $700 later, it runs like a champ. Make sure you service it at regular intervals... a gasket kit ($65) and new rings ($25) should help it at this point. Check the rings first. Hope this helps. BTW- If you're riding in real dusty areas or dunes, the air filter needs to be cleaned and re-oiled quite regularly (every 5-6 hrs!)
Old Feb 11, 2009 | 04:45 PM
ya, its sandy.
thanks
