Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
660 Rhino shut down
Old Apr 8, 2010 | 02:45 PM
cryen's Avatar
Default 660 Rhino shut down
Hi, I have a 06 660 Rhino and the last couple of days it has been shutting down on me. It seems after approx. 30-45 minutes of riding it will just shut down. No warning lights came on. After about 15-30 minutes it will start back up and run fine for awhile then shut down again. When it shut down, the gas filter housing was empty like it wasn't sucking any gas in. Has anybody else had this problem or does anybody know what is causing it? Is it overheating problem or gas problem? It had plenty of oil and coolant in it. thanks
Old Apr 8, 2010 | 03:44 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Look for a blocked or kinked gas tank vent or try replacing the fuel filter.
Old Apr 8, 2010 | 06:37 PM
pwillie's Avatar
Could be a fuel pick up problem,check your fuel pump
Old Apr 9, 2010 | 06:04 PM
cryen's Avatar
ok, i replaced the fuel filter and check all hoses, it took me along time to get it to start. runs fine for now but the filter housing is not filling completely up with gas, not sure if that is a problem. i will have to take it for a longer ride to see if it shuts down again. how do you check to see if the fuel pump is bad? I've read some stuff on the internet that says it may be the stator? thanks for your responses.
Old Apr 30, 2010 | 11:27 PM
Rhino623's Avatar
I had the same problem and it was the fuel filter. It doesn't fill up all the way. You should be good.
Old Jul 26, 2010 | 08:08 PM
Overdrive's Avatar
The fuel pump system on a Rhino is junk. This is a common problem. Replace it with a good low pressure electric pump and your problems will be over
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
Matt123
Sep 29, 2015 01:29 AM
greg74
Sep 10, 2015 07:58 AM
