Question????
Old May 23, 2003 | 11:04 PM
Foty's Avatar
Default Question????
I have a 1997 yahama beartracker atv and its been sitting in the garage for about over a year now and today i just started her up. The fuel was not drained and nothing was done to store it. But today I charged the battery and it started up. The problem is that it will only keep its idle when the choke is pulled out all the way. When we put the choke all the way in the atv will die. Aslo to run the gas out.....we ran it up and down the street for awhile and it hesitated while it was going. What seems to be the problem here. We did stabalize the gas. Thanks for any help.
Joey
Old May 23, 2003 | 11:21 PM
GYTR's Avatar
It could be bad fuel that stabilizer is only good for a few months. Is the fuel tank full? If not try addding some new gas and just run the fuel out or try to drain the old out.
Old May 23, 2003 | 11:24 PM
Ernie660R's Avatar
I would suggest removing the carb and cleaning it. Remove the idle jet out of the carb and spray Carb Cleaner into all of the passages. This should clear up the idle your idling problem.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
