How Important Are Warrior Oil Coolers With These Mods?
Old May 24, 2003 | 12:41 AM
KILLERCUDA's Avatar
Default How Important Are Warrior Oil Coolers With These Mods?
Sup Guys,
I'm going to be getting the Alba Cam & Spring kit,Alba Torque Stuffer,HD Clutch Springs(dont really affect heat) and Jets. Do you think I'll really need an Oil cooler without any problems? Thanks in advance.
Old May 25, 2003 | 09:02 PM
KILLERCUDA's Avatar
Not too important then eh? lol
Old May 25, 2003 | 10:13 PM
95wolv's Avatar
Any air cooled motor can benefit from an oil cooler, to get the maximum from your Warrior after modding it, an oil cooler will help prevent clutch fade and prolong the life of your oil. Also,the top end tends to run a little hot, redirecting cooled oil to the cam area helps a lot.
Old May 26, 2003 | 12:05 AM
mascman's Avatar
I have the Alba kit with ported and polished head. I bypassed my cooler when I broke the engine in to see how hot it was. If you think it runs hot stock...wait untill after the mods! I believe the cooler is a necessity. Check out this Ebay Auction for more info.
I would also forget about the torque stuffer...it didn't seem to do much on my stock motor.
Old May 26, 2003 | 12:56 AM
JakalWarrior's Avatar
buying a torque stuffer with a top end cam is essentially building a hotrod and asking it to breath through a straw. It would take away from top end you get, but at the same time not be enough to make up for the bottom end the cam makes you lose. If you want torque that bad get a cam with different duration. I think all a torque stuffer is really for is so you can get the look and sound of an aftermarket pipe but still have the restriction of stock.
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
