Raptor valve adjustment?
Old May 25, 2003 | 02:57 PM
jimishadow's Avatar
Default Raptor valve adjustment?
the intake adjustment is usually to loosen the gap,the valves get beat into the valve seat and close the gap making the valve early or even hang open.taking off raptor plastic is worst part of job.anyone who never did them should or you will never get it running right,
Old May 25, 2003 | 05:39 PM
Psycho's Avatar
Originally posted by: atvrider82
Also, when I change the oil it says to drain the crankcase and the oil tank. Then put oil in the oil tank and start the engine. My question is does it suck the oil out of the tank into the engine when you start it,
cause the last thing I want to do is start the engine without oil!!!!
On the oil change, after draining both tanks, fill the top tank first and start the Rappy and let it run for about 2 minutes. shut it off and fill the same tank again. The engine will pull the first tank in so don't worry about no oil getting to engine..[img]i/expressions/face-icon-small-cool.gif[/img]
Old May 4, 2012 | 11:12 AM
Jess Zemke's Avatar
does anyone possibly have the valve specs for the raptor 80? we have done everything else but think that the valves need adjustment. mice got our manual so we dont have that anymore.
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 22, 2015 06:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
