Problem with raptor
Old May 26, 2003 | 05:50 PM
wshrdskin's Avatar
Default Problem with raptor
Is it an 01? Pull the choke cable and clean it up. Might be sticking.
Old May 26, 2003 | 05:58 PM
barnes87's Avatar
the smoke clears up after it warms up, it is more noticible when it is idling. It will not idle for more than a minute or so. I pulled the choke out of the carb and found it was stuck open. I cleaned it up and the problem was still there.
Old May 26, 2003 | 06:02 PM
barnes87's Avatar
It is a 2001
Old May 26, 2003 | 06:05 PM
wshrdskin's Avatar
Check the intake boots for cracks outside and inside. Check the float levels. Make sure the flotas aren't sticking. Change the plug just because. [img]i/expressions/face-icon-small-smile.gif[/img] Sounds like you've been checking all the obvious stuff already. Good Luck.
Old May 26, 2003 | 06:06 PM
  #15
RaptorForever's Avatar
I hate to suggest this, but it worked for a friend on his Warrior. Purchase some race fuel 110-114 octane and run it through the engine. There is a good possablity that it will clear up. It shouldn't harm your motor. Unless you are running very lean already
Old May 26, 2003 | 06:07 PM
  #16
wshrdskin's Avatar
Originally posted by: barnes87
The only way i can get it to crank up is to pull the air tubes coming from the airbox off of the carbs.
So your eliminating the filter? I'm sure you've cleaned the filter. Any obstruction in the tubes from the filter to the carbs?
Old May 26, 2003 | 06:09 PM
  #17
barnes87's Avatar
Thanks, i will check that stuff.
Old May 26, 2003 | 06:10 PM
  #18
barnes87's Avatar
yes, the filter is clean and the tubes are clear
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
