Jet KIt???
Old May 26, 2003 | 05:12 PM
MojaveRider250's Avatar
Default Jet KIt???
I got a jet kit and wondering if u guys have any tips on how to put it in because the directions are very confusing. I live in MA and under 3000 feet. I know how to put the jet in, just take off the bowl and unscrew the jet and put in the new one right? And now how do i do the e clip and the needle??
Old May 26, 2003 | 05:26 PM
RaptorForever's Avatar
Default Jet KIt???
To get to the needles, you need to take off the top of the carb, then carfully pull out the inards(can't rember the name) once out of the carb carfully remove the grey plastic plug that you saw once the carb cover was off. Be careful because there is a spring that likes to go flying. Also pay close attention to the washer locations. There are three washer two metal and one plastic. carfully remove the washers noting location. and install them on the aftermarket needle. Reinstall the opposite as you removed. This is how the raptor carb is others are slightly different. You will also find the mixture screw on the bowl side of the carb. Hope this helps
Old May 26, 2003 | 07:05 PM
Default Jet KIt???
Thanks alot!
Old May 26, 2003 | 09:36 PM
Default Jet KIt???
Anyone have anymore advice?
