anyone running a .430 web cam in their wolverine???
Old May 28, 2003 | 12:02 AM
SpDdEmOn's Avatar
Default anyone running a .430 web cam in their wolverine???
Does anyone run a .430 lift web cam on a wolverine, or know anyone who does or has?? I thought i remembered reading about someone who did. You help is greatly appreciated.
Thanks
Old May 28, 2003 | 12:24 AM
MickeyDunlap's Avatar
Its too big of a cam for a 4x4.
Old May 28, 2003 | 10:01 PM
SpDdEmOn's Avatar
What would be the best cam to run for top end without going too big? Does the .430 deaden the acceleration dramatically?
Old May 28, 2003 | 10:31 PM
95wolv's Avatar
That's a top end cam, it will rev higher and give more top speed, but you will loose a ton of bottom end, which will make your Wolverine a real dog. The best set up, unless all you do is fire roads at top gear, is a good low/mid cam that will bump up the acceleration and torque, and leave the top end alone. An auto clutch 4x4 needs the low grunt to get the tires going in the tough stuff, unless you put a huge big bore kit in to get the bottom end back.
Old May 29, 2003 | 04:00 PM
SpDdEmOn's Avatar
THe big bore kit was my full intention. Thats why a top end cam was my preferency. I think with a big bore kit it would be easier to pull. THere is no way i would put that cam in with a 350. My type of riding is odd, this is why i want a good top end cam. I can afford to lose some on the bottom. Thanks for your help.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
