TIRE SHAKE!!!!!
Old May 30, 2003 | 11:57 PM
dirtrider078's Avatar
Default TIRE SHAKE!!!!!
on my blaster my front wheels shake side to side a little bit . Is that normal or is there a bearing in there that is bad???
Old May 31, 2003 | 12:54 AM
MX660R's Avatar
wheel bearings...
Old May 31, 2003 | 02:38 AM
CrAcKhEaD's Avatar
is your hub tight?
Old May 31, 2003 | 02:40 AM
hondaracer305's Avatar
i think its your hub
Old May 31, 2003 | 03:36 PM
how do you tighten the hubs
Old May 31, 2003 | 04:00 PM
GYTR's Avatar
You take your rim off and there should be a big nut with a cotter pin. Take the cotter pin out ant try to tighten the nut.
Old May 31, 2003 | 04:01 PM
GYTR's Avatar
It sounds more like the bushings are shot. Might want to check that
Old May 31, 2003 | 04:09 PM
both wheels are shaking so i should replace the bushings tighten the hubs and replace the bearings???
Old May 31, 2003 | 06:30 PM
whatwasthat's Avatar
any one think that maybe his front wheels arent seating on the bead correctly?
Old Jun 1, 2003 | 12:15 AM
i should have said that the whole tire and rim is moving side to side a small amout but enoug to know that it is
