Warrior just clicks whn trying to start???HELP????
#15
I had the exact same problem with my Raptor this spring. I charged the battery, didn't work. I replaced the fuses, kept popping. I replaced the starter relay, didn't work. I finally found out it was a fried ignition box. I put in a new ignition box and it fired right up on the first turn of the crank.
See if you can find a buddy with a similar quad and swap his ignition into yours. Also check the kill switch wiring to make sure it is wired according to factory specs. It was my aftermarket kill switch that was frying my ignition box. Good Luck! Keep us updated.
RR1
RR1
#16
#17
#18
so it my be my igniton box... well we was worken on it today..and have it a good push start and was running and one of the little black boxes where getting warm and so was the green pug beside the Celenode... but i think i fried something anyways cause last sunday the wires where i had that 20a fuse, cause wires melted together and started smoken when the key was on........so i may of fried the ignition box..
#19
#20
