Big Bore Blaster
Old Jun 5, 2003 | 12:28 AM
dirtrider078's Avatar
Default Big Bore Blaster
I want to make my motor a 260. how much over will i need to go. i know that sounds stupid but i am realy confused. i dont understand the .20 and stuff like that. Because i want to make it a whole 60cc bigger and not .60 also how much more power will that guve me
Old Jun 5, 2003 | 12:33 AM
BlaSteRidr's Avatar
CT offers a nice 240 kit for $1000. But it isn't worth stuffing a lot of money in a blaster.
in my opinion.
Old Jun 5, 2003 | 08:10 AM
i want to go bigger than 240. cuz the faster the better. i would like to bet a shee but i like blasters i just want a faster one.
Old Jun 5, 2003 | 01:12 PM
BLASTERDEVIL2's Avatar
if you want a faster blaster to beat a shee do what i'm doing and put a yz490 in it.
Old Jun 5, 2003 | 01:28 PM
  #15
ZBlaster's Avatar
i would recomend installing a Hot Rod Crank and Toomey or CT pipe and silencer and rejet it. that should help u get the most out of the bore.
Old Jun 5, 2003 | 02:48 PM
  #16
BlaSteRidr's Avatar
Sorry but you will never get your blaster as fast as a banshee, mabie if you put $3000 into it it may keep up with a stock banshee but you rarely will ever see a stock banshee and once they are piped and jetted...your left in the dust. compare 350 TWIN to 200 Single. If you want to be as fast as a Banshee then the first thing you should buy is a pillow...Keep Dreaming!
Old Jun 5, 2003 | 02:52 PM
  #17
some dreams come true lol
Old Jun 5, 2003 | 03:01 PM
  #18
BlaSteRidr's Avatar
Well you can make them really fast by buying the CT 240 big bore for $1000. I know you want yours to be a 260 but anything above a 240 is really really expensive...like $1600, and you can't just go to a machine shop and get it bore.
Old Jun 5, 2003 | 03:31 PM
  #19
why not wouldent it work. What all would you need to do besides new piston maybe a crack and
pipe
Old Jun 5, 2003 | 04:38 PM
  #20
BlaSteRidr's Avatar
Do you know how the blaster engine works? ill do a breif explanation of why you can not just go and bore the engine, buy a piston and go.
Exaust ports will still be stock so you will feel ZERO power increase. to re-port it, it will cost you about $450 bucks.
I dont know where you could buy a 260 bore piston?
You see, a bore wont give you power...It will allow you to get more power with further mods, like pipe, Carb, Jet, Porting, Wensco Piston, Reed Cage, Higher octane fuel, and possibley a better cooling system. Now without all these mods and High octane racing gas, you wont feel anymore power. Also When you do a "big" bore on a blaster, you have to buy a extended swing-arm. all this stuff is going to cost you a lot of money. If you want to make your blaster really fast, and you want to stick with the blaster, Then buy a welder and Wal-Mart for $200, buy nice metal, and go onto Ebay and buy a yz250 motor, then weld what you need to to make it bolt on, buy the right size sprockets for the engine and axle>>I think 14 tooth<<>> 42 Tooth, and then see how much you like it!
