buying a banshee?
Old Jun 12, 2003 | 02:18 AM
Fishpony's Avatar
Default buying a banshee?
no way?? hours?? anyway else to tell?
Old Jun 12, 2003 | 06:13 AM
BlackWidow's Avatar
Take a good look at the bike. If it looks like it's in good shape then it probably is. Take a good close look at it. Is there paint chipping anywhere?? Is there wiring that has been repaired? How are the tires? Are they stock? How much are they worn? All of these will give you a little insight on how much it's been ridden and how well it's been taken care of.
In my opinion, if it's a 99 and going for the price you're talking about I would take a good look at it. That would be a pretty good price out here. Try not to get attached to a particular bike unless you know you can't go wrong. Get some sort of idea from your buddies.. they will probably be willing to go with you to look at the bike.
Good luck!
Old Jun 12, 2003 | 02:15 PM
Fishpony's Avatar
thanks for the help guys im gonna go over with a couple of my friends today to take a better look at it.
warrior620 why dont you reccomend this for my first quad? because its a banshee or because of the price?
Old Jun 12, 2003 | 03:40 PM
FMF's Avatar
FMF
I would not reccomend this for your first quad either. Because the Banshee is a lot of quad for a Beginner. And we do not want to see any one get hurt.
I would say to get a Blaster for your first Quad.
Old Jun 12, 2003 | 03:58 PM
  #15
HubMonkey's Avatar
If you are serious take a compression check of each cylinder and you can tell if it is in good shape. If they won't let you do a compression check... WALK AWAY.
Hub
Old Jun 12, 2003 | 06:01 PM
  #16
Fishpony's Avatar
how do i do a compression test? and its not like i've never rode before i used to own a 3wheeler and just about everyday last summer i rode a 400ex after work
Old Jun 12, 2003 | 08:26 PM
  #17
HubMonkey's Avatar
Stock Compression should be..... (per Cylinder)
Sea Level 130 psi
1000Feet 124 psi
2000Feet 118 psi
3000Feet 112 psi
4000Feet 106 psi
5000Feet 100 psi
Use a compression gauge. You should be able to get or borrow one from a local Auto Parts store.
Hub
Old Jun 13, 2003 | 01:01 AM
  #18
Fishpony's Avatar
allright thanks guys.. still not sure about it almost hope itll get sold so i dont hafta decide
Old Jun 13, 2003 | 01:11 AM
  #19
Hossblur's Avatar
The question I would ask is why if the bike is stock and it hasn't been riddedn excessively why does it have a new clutch? Who did the work? Also the price sounds just a little high for a stock shee. I would recommend though getting what your friends ride, or at least something that is in the same class. Also, the shee IS NOT a good track bike so if you not into dune riding I would go with a 4 stroke. The basic rule of thumb is:
Dunes= shee, raptor, ds,
Track= Any of the 400's including the warrior, 250r and its clones
Woods= hard to beat the warrior, but the 400's do well here.
Old Jun 13, 2003 | 01:15 AM
  #20
Fishpony's Avatar
yea i was kinda wonderin why it had a new clutch in it.. i thought that was a pretty good price with it being a 99' but guess not maybe ill just do a little more lookin around. maybe look at some 400ex's
