Adjusting The Valves (Help)
How hard is it and what do you need to do it? are there any webpages that show how to do it? or is this something that i should take to a shop and have them do it... it costs me 100 bucks the first time they did it but that was 14 months ago, will they go outa whack after alota ridding? Thx for the help guys!
The intakes tend to tighten up. here's the tools needed and a few tips.
Tools
Torque wrench
5mm allen socket
10mm socket
19mm socket to turn engine
10mm, 17mm wrenches
The tool to turn adjuster would be nice but I use needle nose pliers
Angled feeler gauge .005" intake .007" exhaust
Big flat head screw driver to remove timing covers
Turn engine over counter clockwise when aligning the timing marks. After your intakes open then close it's about a half turn of the crank to align the marks. There are two sets of marks that look like this ( ll and l ) use the (l) mark you'll come to the (ll) marks first.
When making the adjustment I snug the lock nut just enough that I can still turn the adjuster. Then snug the nut down a little more with a wrench while holding the adjuster so it does'nt move, then torque and recheck clearance.
Tools
Torque wrench
5mm allen socket
10mm socket
10mm, 17mm wrenches
I would say to try it yourself, because it actually isnt that hard to do on your own. The first time is a little tricky but just dont rush and do it right. You can also save yourself alot of money by doing it on your own.
sixsixt is right, if you want pictures aswell, there is a valve adjustment guide on my site.
http://www.raptortranny.com/valvesadj1.php
awsome thx guys.... last time it was 100 bucks to have the guy mess with it, wich i wasn't to mad about because he found that a enguine mount bolt had fallen off lol....... how offten should i check the vavles?
fordfaithful21
Dec 7, 2015 05:52 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
