CT Pipe for Raptor
Old Jun 14, 2003 | 12:46 AM
VegasRaptor's Avatar
Default CT Pipe for Raptor
Ugintel,
Thanks for the feed back. I'm ordering mine on monday!
Old Jun 14, 2003 | 01:41 AM
RepTaR660r's Avatar
I heard the disc style exhausts suck because the jetting will change on you... I've seen a stock raptor beat a piped CT raptor at the river....
Old Jun 14, 2003 | 02:04 AM
Ugintel's Avatar
One must consider the variable in a race.
#1 Horse Power (right power curve - wich CT HAS)
#2 Tires (Size and Type and Paddle count - Weight)
#3 Gearing (This is about the most important part)
#4 Rider Weight (If you weigh 220lbs. and I weight my 150lbs. thats 70lbs. difference)
#4 Over all weight (This is hard to drop but can be done)
Once you master all of those you will have one bad *** machine...... BUT if the other guy drops a 727 in his bike and had the right paddles AND OR gearing chances are your screwed..... but if your racing the same machines you'll win every time.......
Old Jun 16, 2003 | 11:42 PM
maddog56's Avatar
Originally posted by: AlaskaYFM
Originally posted by: hondaracer305
i know they give a lot of hp, almost the most out there.
almost?! [img]i/expressions/face-icon-small-confused.gif[/img]
last I heard they give the most for built engines...
Yes, they do give the most hp, but that is because they come with the k&n and kit, and you pay extra for them too. If you tested other pipes with the filter kit, you would have noticeably different results. Ct has a very good pipe, but they arent rated on a level playing field.
Old Jun 17, 2003 | 12:11 AM
  #15
AlaskaYFM's Avatar
My CT Sonic kit did not come with the Pro Flow kit-- bought it seperately. Of course, that was back in 2000 when they first released them... still don't have the correct header springs for it, either...
If you are referring to that one issue of crackwheeler magazine (as far as level playing fields), it seems that everyone takes from it what they want from that test. I still haven't seen anyone post better dyno numbers that CT Racing.
bmxatv10
Oct 14, 2022 06:23 PM
mrtidy
Feb 3, 2016 05:00 PM
black_thunder
Sep 22, 2015 07:59 PM
greg86hd
Sep 16, 2015 12:32 AM
Alex Rodak
Sep 12, 2015 09:39 AM
