Need porting options for 686 w/stage2 cam
Old Jun 16, 2003 | 11:55 PM
14mins's Avatar
Default Need porting options for 686 w/stage2 cam
Is lazer mike promising you any numbers?? I am sorry for calling you a idot, lier and whatever today. I have tried to chill from your comments lately, but you knew the correct answer when you posted it on the other thread.
Old Jun 17, 2003 | 12:12 PM
Hiram's Avatar
I contacted both yesterday spoke to Nick and Bob both are asking the same amount $415 and decided to go with craycraft. I was asked if I was interested in replacing the valves with S/S ones and wasn't sure what the advantage or PRICE so I said no, now can someone tell me a little more and is it worth it?
Old Jun 17, 2003 | 12:23 PM
14mins's Avatar
Hiram- I think the valves are worth it but pricey. Stainless valves flow better and last longer. I have seen a lot of stock valves come thru craycrafts shops. The out sides edges are beat up pretty good. You can redress them but i have seen a lot of guys just replace them. Either way a valve job is included in the head porting. If you are a die hard atv'er and want the best replace the valves. I went a long time before i went to the stainless. If you just want a fast ride leave the stock valves in. If you want every edge get the stainless.
Old Jun 17, 2003 | 01:24 PM
Hiram's Avatar
I stick to the stock one for now, and wait until mine start to wear and then upgrade, I have to leave the wife some money in the bank.
Old Jun 18, 2003 | 12:02 PM
  #15
trx250Rob's Avatar
What are you doing Hiram? You are going to make me have to put on my race gas dome!
Old Jun 18, 2003 | 12:45 PM
  #16
Hiram's Avatar
Trx250rob, that's right the head is off and on it way, so the 686 will be really complete and I'm getting a 15t for the front to play and experiment with the gearing, ...............so VP c12 race gas is really good give it a try after you change your dome!!!! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 18, 2003 | 01:08 PM
  #17
trx250Rob's Avatar
So I guess you will not be doing any riding this weekend. I might go out for a little bit on Sunday. I have to dial in the jetting, there is room for improvement.
You heard about Max's.
Old Jun 18, 2003 | 02:02 PM
  #18
BlueLeader's Avatar
let us know how it turns out.
Old Jun 18, 2003 | 07:45 PM
  #19
ALIENraptor's Avatar
Yea Rob u should switch to the race gas dome. Im sure it'll smell alot better.
Old Jun 18, 2003 | 08:14 PM
  #20
trx250Rob's Avatar
I haven't done it because it is difficult to get the gas when you are in a bind. But, now I'm going to have to, can't let Hiram get the advantage.
