Need help with Brakes
Old Jun 16, 2003 | 09:31 PM
SSports578's Avatar
Default Need help with Brakes
I just got my warrior out for the summer and the brakes were locked up. I bled the brakes to relieve the pressure and now there is no pressure at all. I tried pumping, holding, and bleeding the brakes countless times but I still get no pressure. I tried everything that I could find in the forum but nothing worked. Could someone give me a hand with this?
Old Jun 16, 2003 | 09:47 PM
MMwildman's Avatar
I don't know the Warrior setup, but it sounds like you left the parking brake on during storage? Then one of the pistons is stuck, in the master, or slave, at the wheel. Is it the rear brakes that are locked up?
Old Jun 18, 2003 | 12:16 PM
SSports578's Avatar
I did not leave the parking brake on during storage and it is the front brakes that I'm having trouble with.
Old Jun 18, 2003 | 01:34 PM
HoundDog06's Avatar
That s@cks man. I would check to make sure there are no leaks in the hoses anywhere. Make sure your reservoir has plenty of fluid and have someone hold pressure. Then check to see if you can find any leaks. In something as high pressure as a brake system, even a pinhole can cause major probs. Let us know how it goes.
~HoundDog
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
