I bet no one can solve this......well maybe
Old Jun 22, 2003 | 11:04 AM
ekeller's Avatar
Default I bet no one can solve this......well maybe
It is getting fire both ways. This is the most screwed up project I have ever had! It runs great when it is pull started, but it will not even attempt to start with the starter. I know it is out of gear, as this yamaha will not allow the starter to spin with the trany in gear.
Old Jun 22, 2003 | 04:29 PM
warrior007's Avatar
Hmmmmm...
I wonder if its possible there is a decompression mechanism that is only working (malfunctioning) when the pushbutton starting. Try a compression test (cheap guages are like $20) and see if you are getting the same results for both pull and button starting, the cheap guages arent all that accurate but will tell us what we need. The only thing left after that is fuel..
Old Jun 22, 2003 | 04:58 PM
sixsixT's Avatar
Like 007 said spark,compression and fuel. If your compression is good it could be crank seals or an air leak from somewhere else.
salixair
Nov 3, 2015 08:25 AM
firsttimerider
Sep 26, 2015 01:49 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Steeldon
Sep 9, 2015 09:38 AM
