Raptor Steering stems
Old Jun 20, 2003 | 10:40 PM
maddog56's Avatar
Default Raptor Steering stems
I was riding last weekend and rolled my raptor. I was braking and turned a little too sharp. Low speed, 15mph max, probably less. In anycase, the quad ended up on its top. I bent the handlebars, a tie rod, and it seems the steering stem. It was more of a soft roll than a crash, so I dont understand why the thick tubed steerign stem bent as well. The left end of my new handlebars is a good inch lower than the right. Is the stem known to be weak, or did I crash just right to bend it? Also, any ideas on how to fix or what to replace it with and where I can get it would be appreciated. Thanks.
Old Jun 20, 2003 | 11:09 PM
sixsixT's Avatar
Just a message for those of you that have bent your steering stem or are planning to in the near future. I just got mine retubed in 4130 chromemoly ("1.25x.120) from Wizard fabrications in Riverside California. He does a great job for $125.00. The man makes sand cars for a living and is a very capable fabricator. He does a lot of trick aluminum side panels, consoles, wing trunks, fuel tanks etc... He's a got a car on the cover of the new sand sports coming out this month.
Old Jun 21, 2003 | 12:27 AM
RaptorRacer1's Avatar
Are you sure it is the steering stem? The first time I rolled mine over I bent the handlebars and the steering knuckle or yoke at the bottom of the stem. The T-shaped piece that the inner tierod ends bolt into. Check that before you invest in a new steering stem. I think that part runs $20-30. Good luck!!
RR1
Old Jun 21, 2003 | 01:17 AM
warrior007's Avatar
I bent that part aswell and thought it was the stem. it actually bent when my tierod did not
Old Jun 21, 2003 | 01:20 AM
maddog56's Avatar
I think its the steering stem because when i put my new handlebars on, they are lower on one side still. if it was just the bottom mounting bracket, it wouldnt affect the new bars, would it?
bmxatv10
Oct 14, 2022 06:23 PM
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
